R/r - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 04-03-2009, 08:56 PM Thread Starter
D2u
D2u
D2u's Avatar
R/r
Ok im sure this is on the forum somewhere,but can someone link a pic of the R/R ,and where it should be relocated to,and a quick how to. Thank you in advance!
1992 VN750 22,350 miles 18,700 when I bought it last year 04/17/2008
Streetshield EX
degoat
drilled mufflers
Capped (soon to be coaster)
Custom Grips
Wide blade levers
Throw over leather saddlebags
Deka MF AGM ETX15L
NGK Iridums
DIY Brackets,and highway pegs
To do list.
custom seat
teardrop mirrors
DIY Floor boards
D2u is offline
post #2 of 10 (permalink) Old 04-03-2009, 08:59 PM
CWO3 Navy (Retired)
cliffhusn's Avatar
If you have degoated then you probably don't need to relocate the R/R since you've removed the heat source that caused the problems in the first place.
The Flag on my bike honors those who serve our Country and those who have served!
cliffhusn is offline
post #3 of 10 (permalink) Old 04-03-2009, 09:32 PM Thread Starter
D2u
D2u
D2u's Avatar
AH good one less thing to do this weekend Thank you.
Streetshield EX
degoat
drilled mufflers
Custom Grips
Wide blade levers
Deka MF AGM ETX15L
NGK Iridums
To do list.
custom seat
teardrop mirrors
DIY Floor boards
D2u is offline
post #4 of 10 (permalink) Old 04-03-2009, 09:35 PM
93VN750's Avatar
It's on the bottom of the battery case.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #5 of 10 (permalink) Old 04-03-2009, 10:14 PM
Originally Posted by 93VN750 View Post
It's on the bottom of the battery case.Jon
And if you are still running the lead acid battery and haven't replaced it with a MF battery you still might want to move the R/R from under the battery box away from any spilled or leaking acid... Or at least I did mine...
post #6 of 10 (permalink) Old 04-04-2009, 04:18 AM
750Doug's Avatar
As mentioned it's mounted under the battery box from the factory. Here's a couple pics of places folks move it to, the first pic is the most popular choice because it's close enough to the stock location that the wiring harness plug will still reach to it.
Somebody around here (don't remember who) sells a relocation bracket, some people just come up with their own. I used simple strip steel when I moved mine, drilled some holes in it, painted, and mounted to the peg bracket bolts.
If you browse through the member gallery photo's, you'll see alot of different options for mounting hardware. Most just do their own thing with it.
Here's a side mount shot, (most popular) and somebody who took the time to do a front mount-
ID:	1548   Click image for larger version
750Doug is offline
post #7 of 10 (permalink) Old 04-04-2009, 07:44 AM
CWO3 Navy (Retired)
cliffhusn's Avatar
Good catch on the battery, yes, get a MF battery. No more acid overflow to worry about and it will hold the charge longer.
post #8 of 10 (permalink) Old 04-04-2009, 09:44 AM
Kawika
davewex's Avatar
bulldog485 sells a relo bracket kit and I think you can even ask him to powder coat it, too.
LETS RIDE!! VROC# 26137
☠ Black Candy ☠ '07 Mean Streak 1600
☠ Blue Crush ☠ '95 VN750-A11
davewex is offline
post #9 of 10 (permalink) Old 04-04-2009, 11:21 AM
fergy's Avatar
Or you can make your own. You asked about a writeup and there's one in my sig on making your own. Parts are cheap.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #10 of 10 (permalink) Old 04-04-2009, 01:19 PM
Thats it, the one I did, Fergy's, couldn't remember (CRS) but it is simple, good, and cheap, had to be simple I did it...lol...
