Epitome of paranoia - Page 4 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 24Likes
post #31 of 37 (permalink) Old 01-18-2019, 11:42 AM Thread Starter
2003 Vulcan 750/Sidecar
Hench's Avatar
Belated reply
Thanks, ordered not one but 2 lower hoses. Leading mount on the sidecar loosened enough to punch hose. I fixed the hose
the same day. (and the mount!)
Autozone has 1.5 inch emergency splice kits. Had to cut splice down to .75 inch on each side to fit the bend.
Looks fugly but has held up for a week's riding. Could work if you're on the road and can't get a new hose.
Thanks!
2003 VN750
Velorex 562 sidecar w/trunk
2-wire mod
Headlight power switch
Manual fan switch
Shingigen SH775
Blue wire mod
Yellow wire mod
RLU removed
RR moved
Voltmeter relay wired
Coils direct wired w/relay
handicap mods:
extended foot shift
heel shifter
extended brake pedal
Hench is offline
post #32 of 37 (permalink) Old 03-26-2019, 06:16 PM Thread Starter
Hench's Avatar
It's DONE!!!
All electrical mods, mccts adjusted, splines lubed and fresh oil, floorboards installed, RR relocated. Amp meter shows 13.7 charging but reads 14.4 at battery charge port. (cheap analog meter).
Now it's riding and routine maintenance!
I'm happy.
OleDirtyDoc and roadpouring like this.
2003 VN750
2-wire mod
Manual fan switch
Shingigen SH775
Blue wire mod
Yellow wire mod
RLU removed
RR moved
handicap mods:
extended foot shift
heel shifter
Hench is offline
post #33 of 37 (permalink) Old 03-26-2019, 07:01 PM
Location: southern, western, middle Tennessee backwoods
Originally Posted by Hench View Post
It's DONE!!!
I'm happy.
Yay!
"I need yo clothes, yo boots and yo motocycle."- Uncle Bob
roadpouring is offline
post #34 of 37 (permalink) Old 03-26-2019, 08:43 PM Thread Starter
Hench's Avatar
Did the ignition coil direct wire to the battery today. Bike starts better, idles runs better and seems to have more power. Should have done it sooner, seems there was a wiring problem there. Used the write up here so can go back if needed. But I don't think I will.
Even had to back the idle down.
Still Happy! And the voices are quiet.....
OleDirtyDoc likes this.
2003 VN750
2-wire mod
Manual fan switch
Shingigen SH775
Blue wire mod
Yellow wire mod
RLU removed
RR moved
handicap mods:
extended foot shift
heel shifter
Hench is offline
post #35 of 37 (permalink) Old 03-28-2019, 01:19 PM
I'm a rider
One1's Avatar
It's DONE!!!
I'm happy.
VN: Hold my beer.
1981 KZ750
1988 Vulcan VN750 (red)
2005 Vulcan VN750 (silver)
(2) 1994 Vulcan VN750 (red)
One1 is offline
post #36 of 37 (permalink) Old 04-10-2019, 04:44 PM
Originally Posted by One1 View Post
VN: Hold my beer.
LOLOL
Sent from my A502DL using Tapatalk
post #37 of 37 (permalink) Old 05-03-2019, 05:19 PM Thread Starter
Hench's Avatar
I was wrong!!
Since I was "done" I've had to add handicap mods. Extended shift toe bar, extended/widened brake pad and a heel shifter.
Never ends, do it!!! :~)
2003 VN750
2-wire mod
Manual fan switch
Shingigen SH775
Blue wire mod
Yellow wire mod
RLU removed
RR moved
handicap mods:
extended foot shift
heel shifter
Hench is offline
