Epitome of paranoia - Page 2 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 24Likes
post #11 of 37 (permalink) Old 12-31-2018, 01:21 AM Thread Starter
2003 Vulcan 750/Sidecar
Hench's Avatar
Pulled the RLU yesterday. Got the cold crank-crank-crank-backfire on first start at 31F this morning. Didn't have that before.
Removed the RLU jumper and installed waterproof switch. Starts on one crank again.
I'm done with the mods! Thanks to the forum for listing these and the help with them.
And the voices say "Are you done???" :~)
roadpouring likes this.
2003 VN750
Velorex 562 sidecar w/trunk
2-wire mod
Headlight power switch
Blue wire mod
Yellow wire mod
RLU removed
RR moved
handicap mods:
extended foot shift
heel shifter
extended brake pedal
Hench is offline
post #12 of 37 (permalink) Old 12-31-2018, 01:28 AM
Location: southern, western, middle Tennessee backwoods
Good thread!
Thanks!
Valuable for foreseeable future needs.
"I need yo clothes, yo boots and yo motocycle."- Uncle Bob
roadpouring is offline
post #13 of 37 (permalink) Old 01-04-2019, 06:09 PM Thread Starter
Hench's Avatar
Well....
I have to admit to my Kawasaki VN750 engine sounds noobishnis….
Seems it wasn't the cam chains still clanking after minimal readjustment.
Today the voices told me to tighten the sidecar bolts again. While I was doing that, they said "check them exhaust stud nuts... Stud". I did.
In 60+ years of work on engines I've never heard an exhaust leak sound like metal clanking. Always a peeping or roar at
the manifold gasket.
The bike is now quiet. Minimal clicking when cold, very quiet when warmed up. I'm happy!
Yep, I'm a noob. But learning! :~)
2003 VN750
2-wire mod
Blue wire mod
Yellow wire mod
RLU removed
RR moved
handicap mods:
extended foot shift
heel shifter
Hench is offline
post #14 of 37 (permalink) Old 01-09-2019, 12:51 PM Thread Starter
Hench's Avatar
So here I am at the curb admiring my "finished" hack. All electrical mods, check, mccts adjusted, check, new oil/filter, check, splines lubed, check, tail trunk on the hack, check, hack adjusted and tight, check. Yes!!!!
Then the voices said "youze know there's no kickstarter…." "Yeah, I know.." "So what if youze needs a jump?"
I now have an external charging/battery monitoring/jump port so I don't have to pull the seat.
Does it ever end?
2003 VN750
2-wire mod
Blue wire mod
Yellow wire mod
RLU removed
RR moved
handicap mods:
extended foot shift
heel shifter
Hench is offline
post #15 of 37 (permalink) Old 01-09-2019, 01:10 PM
ubertalldude's Avatar
I went and got some M6x1.0 threaded thumb screws from Ace Hardware to replace the seat bolts, that way if I ever need a jump or to access the battery I don't even need any tools, just open the toolbox and unscrew the seat by hand
roadpouring and Hench like this.
Earshave+Rejet (38/135) – NGK Iridiums – MCCT Conversion – Slipstreamer S03 Windshield – Custom Extended Backrest – Custom Highway Bars – MOSFET R/R – LED Underglow – Volt+USB In-DashTwo-Wire & Blue-Wire Mod – Satin Black Engine Paint – Dampers Parts - Jets: Main=99101-393(#132 stock)/Pilot=n424-22 Pilot(#38 stock)
ubertalldude is online now
post #16 of 37 (permalink) Old 01-09-2019, 10:48 PM
kryptonianjorel's Avatar
Uh, roll down the hill and dump the clutch! I've started it a few times this way. Just don't run out of hill before you get it started
kryptonianjorel is offline
post #17 of 37 (permalink) Old 01-10-2019, 10:01 AM Thread Starter
Hench's Avatar
I've thought of that but the voices said "what if youze ain't on a hill? Youze gonna push a 700 pound bike and sidecar up a hill? We wanna see dat, Slick! (snicker snicker)"
Thus the jump port and booster cables in the sidecar.
Today's mod. External holder on the sidecar for my cane!
OleDirtyDoc likes this.
2003 VN750
2-wire mod
Blue wire mod
Yellow wire mod
RLU removed
RR moved
handicap mods:
extended foot shift
heel shifter
Hench is offline
post #18 of 37 (permalink) Old 01-10-2019, 10:19 AM
https://www.ebay.com/itm/Noco-GB20-L...72.m2749.l2649
These have been mentioned before on this forum somewhere.
Expensive, but so can it be if stranded.
Got one. It's really nice.
Can be used to help other folks too, whether MC, cars or trucks.
Hench likes this.
post #19 of 37 (permalink) Old 01-10-2019, 10:33 AM Thread Starter
Hench's Avatar
Yep! I see a purchase in the future!
2003 VN750
2-wire mod
Blue wire mod
Yellow wire mod
RLU removed
RR moved
handicap mods:
extended foot shift
heel shifter
Hench is offline
post #20 of 37 (permalink) Old 01-10-2019, 10:56 AM
I tried to find some thumbscrews but nobody local had them, and I didn't get around to welding washers on the bolts.
For now, I carry a 1/2 drive, 10mm deepwell socket in the toolbox, and just tighten the seat bolts finger tight.
