laid it down for a hooker - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 3Likes
  • 1 Post By wopaness
  • 1 Post By Goofyfoot2001
  • 1 Post By boscoe
post #1 of 9 (permalink) Old 10-28-2018, 10:38 AM Thread Starter
Boy Howdy !!
wopaness's Avatar
here's one I bet you don't get too often, going down the seedy part of my town I slowed to cross some R.R, tracks, when I looked up Pow there was a lady of the nite, had to lay the bike down. I came away with minor damage, but somehow one of my screws that holds the speedo faceplate came loose. the unit looks to be sealed so my Question is can anything be done other than replacing the unit, I even tried using a magnet and while I was able to get the screw upright and in the hole I could not turn it.
VN-700 / Ca. model
M.F.G. Date / 11/84
Vulcan off the line / #003216
Mile's / # 06288.2
A.F.T. battery
New stater
New starter
Rewired bike with 18 gage
NGK DPR7EIX-9 spark plugs
New gas lines
Rebuild carburetor with new O-rings
Rebuilt cooling system
Replaced master cylinder glass
Trimmed base on rear turn signal's
The Greatest tragedy
is indifference
wopaness is offline
post #2 of 9 (permalink) Old 10-28-2018, 12:42 PM
Not sure why you "laid it down" but disassembling he speedo is fairly difficult. You could try drilling a hole with a carbide bit over the screw hole and then sealing after you tighten the screw back up with clear epoxy ora rubber plug.
post #3 of 9 (permalink) Old 10-29-2018, 07:43 PM
Hmmm hit a hooker or lay the bike down? There's an age old question, if the hooker dies,do you still have to pay her?. Back on topic( yeah I'll bet no one expected to hear me say that lol) did the screw not turn at all or were you just not able to get a screwdriver on it?
post #4 of 9 (permalink) Old 10-29-2018, 09:15 PM
Birga's Avatar
This, ^^^^
Disassembling the speedo or tach is a PITA. I've done it on mine, and when the tach still wasn't fixed (broken wire on the spring, my ham fisted soldering fixed it beyond repair) I just Ebay'd an electronic unit.
If you try it, Step 1. remove the gauge from the dash. Step 2. take the back plastic part off, should just be a wiring connection, the speedo cable, and two screws. And the Odo/trip knob, it's got a screw in the end. Step 3. using a small screw driver or pick gently pry up the back side of the chrome trim ring. Yes the ring is crimped on. Yes you could just cut the white plastic under the chrome cover, and tape or epoxy it back. Step 3.5. clean up the blood and put a band aid on your hand. And lastly, pull the trim ring and front glass off.
To reassemble it just place the front back on, and using a flat head, roll the back of the trim ring back down. You were careful about prying it up right? did it in multiple passes? When it's mostly back down, use a vise with jaw protectors and place the gauge in so your squeezing the lip on the front and back of the trim ring, this is to flatten and crimp it back down. Be Gentle.
Birga is offline
post #5 of 9 (permalink) Old 10-31-2018, 01:50 PM Thread Starter
Boy Howdy !!
wopaness's Avatar
Thank you, that sounds like a doable project. I will let you know how it came out
VN-700 / Ca. model
M.F.G. Date / 11/84
Mile's / # 06288.2
A.F.T. battery
New stater
New starter
New gas lines
is indifference
wopaness is offline
post #6 of 9 (permalink) Old 10-31-2018, 02:01 PM Thread Starter
Boy Howdy !!
wopaness's Avatar
thank's for all your input, this forum has over the years been a god send. speaking of "oh god" the thing was the R.R. tracts are so beat up you could wedge your front tire into a sudden stop with plus it being night I was so focused on the tracts when I looked up she was right there, of course she could pay nothing and I declined pu**y payments. anyway once more thank you.
DACataldo likes this.
VN-700 / Ca. model
M.F.G. Date / 11/84
Mile's / # 06288.2
A.F.T. battery
New stater
New starter
New gas lines
is indifference
wopaness is offline
post #7 of 9 (permalink) Old 11-07-2018, 03:27 PM
HAHA - "I was able to get the screw upright and in the hole I could not turn it." Hooker heh heh
OleDirtyDoc likes this.
post #8 of 9 (permalink) Old 11-08-2018, 11:12 PM
boscoe's Avatar
Lay the hooker down, hit the bike - - - More fun! (and more socially acceptable).
In God we trust. All others pay cash.
boscoe is offline
post #9 of 9 (permalink) Old 11-09-2018, 03:06 PM
But then you still have to pay the hooker
