Ticking when hot - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 03-26-2009, 04:54 PM Thread Starter
Ticking when hot
I have noticed that my 85 Vn700 heats up a lil and while in idle she has a tick when I am sitting in traffic. Is this bad.
timqueen1987 is offline
post #2 of 7 (permalink) Old 03-26-2009, 05:06 PM
The Professor
lance328's Avatar
My 700 had the same problem, it was a front intake lash adjuster, it wore down the cam lobe and rocker. your could be the same or it could be your ACCT. Search ACCT.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 7 (permalink) Old 03-26-2009, 06:38 PM
Calif Rider
weh44att's Avatar
It may also be the oil you are using. A lighter weight oil in not good in hot weather area's. Have you changed to a lighter weight oil on your last oil change. Most likely it is the ACCT's getting a little weak.
2004 25,500 miles
Led tail light enhancement
Homemade floor boards
Headlight modulator
Extra heat sink on R+R
R+R relocation
Homemade driver's backrest
Fused Stator
Mcct conversion-cost 4.50
Ride-on in tires
iridium plugs
coil pickups adjusted.
weh44att is offline
post #4 of 7 (permalink) Old 03-26-2009, 07:40 PM
Where do you live tim? Welcome to the Vulcan madness. If you fill out your profile, your location shows up in the upper right corner with every post. With heat related questions like yours, it can help to know if you live in a hot place. I doubt that there is anywhere in North America where it is hot enough yet to thin 10w-40 oil out enough to be a problem. However we have members down in the tropics too.
post #5 of 7 (permalink) Old 03-26-2009, 08:52 PM Thread Starter
I live in Kentucky.... I used 20-50 that is what the dealer gave me. Should I need to switch to 10-40. It isnt a loude tick. Only noticable when really listeneing.
post #6 of 7 (permalink) Old 03-27-2009, 12:18 AM
Jace Bror's Avatar
stop listening...
Sold 750 (9-09)
Mustand Seat (6-09)
Balanced Carbs (4-09)
Adjusted Mix Screws (4-09)
R/R Relocated (3-09)
Splines Lubed (3-09)
Painted flat blak (3-09)
Kuri grips (8-08)
Kuri Longhorn pegs (8-08)
Iridium Plugs (8-08)
Highway bar/ engine guard(FS)
Facebook ID Eli Gaffke
Jace Bror is offline
post #7 of 7 (permalink) Old 03-27-2009, 12:40 AM
do the old garden hose trick take you a three foot piece of garden hose and put it up to one ear ,it works better if you use an earplug on them ear without the hose ,get your bike up to temp and when the ticking starts use the loose end of the hose to listen to various places on the engine i.e. the front head the rear head ,the ACCT's and the transmission and when you hear it considerably louder in one location check for problems there first,be sure to hold the free end of the hose pretty close to the section you are checking,with a little practice you will learn to isolate noises to a pretty small area,Don't panic because you hear noise everywhere you stick that hose but listen for the specific noise you are trying to isolate,the other noises are just things turning round and round an going up and down as normal ,that you normally don't hear for exhaust noise,poor people have poor ways an just cause granpa did it that way doesn't make wrong,we all need a little low tech ever now and then,Denny
