Help - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 4Likes
  • 1 Post By OleDirtyDoc
  • 1 Post By One1
  • 1 Post By Paulywog
post #1 of 10 (permalink) Old 06-28-2018, 12:43 PM Thread Starter
cepak4772's Avatar
Help
On my way to work my bike stalled out on me. I was sitting a a red light and when it turned green I started to accelerate and boom died, started right back up and as I accelerated to take off it tried to stall again. I gave it more throttle up to around 3,500-4,000 rpms and it took of ok. Spit and sputtered till I got back up to around 3,000 rpms then ran great. Every gear change that dropped the bike below 3,500 rpms cause the same spit and sputter till a higher rpm was reached. Do I need to pull and clean carbs? Spark plugs seemed ok when I checked them last night, not burnt and ashy or wet. Also when its spits and sputters the exhaust smells heavily of raw unburt fuel. Plug wires possibly?
Sent from my SM-G965U using Tapatalk
cepak4772 is offline
post #2 of 10 (permalink) Old 06-28-2018, 01:43 PM
I'm a rider
One1's Avatar
Anything at low RPM is pilot jet, Mid rpm is main jet.
If voltage is good, clean your jets.
1981 KZ750
1988 Vulcan VN750 (red)
2005 Vulcan VN750 (silver)
(2) 1994 Vulcan VN750 (red)
One1 is offline
post #3 of 10 (permalink) Old 06-28-2018, 03:38 PM
One of your carbs is flooding out due to a sticky float needle. Look up Wolfie's back blow method in the sticky section of the carburation board
kc2dgq likes this.
post #4 of 10 (permalink) Old 06-28-2018, 04:47 PM
I'm a rider
One1's Avatar
that too.
OleDirtyDoc likes this.
1981 KZ750
One1 is offline
post #5 of 10 (permalink) Old 06-29-2018, 11:25 AM Thread Starter
cepak4772's Avatar
Didn't do the blow back yet, but on my way home last night and on my way to work the bike ran great. What would cause that to intermittently happen? Nothing was done to the bike to make a differance. I'm so frustrated, sometimes it will act up and others it runs beautifully. Is that just the nature of the beast or something else?
post #6 of 10 (permalink) Old 06-29-2018, 11:40 AM
Maybe small pieces of crud that stick the needle open,then it passes through,the needle closes, then another piece of crud...
One1 likes this.
post #7 of 10 (permalink) Old 06-29-2018, 02:48 PM
Thumbs up
Maybe you could try running some Seafoam through it. A lot of guys including me get good results from it.
roadpouring likes this.
Paulywog is offline
post #8 of 10 (permalink) Old 06-29-2018, 03:57 PM Thread Starter
cepak4772's Avatar
I went to walmart to get some and they were sold out... so I grabbed the walmart brand hoping it would do in a pinch but not sure it's working
post #9 of 10 (permalink) Old 06-30-2018, 04:19 AM
I'm a rider
One1's Avatar
Been through that a few times with several of my VN's. Early in the season mine did that and it usually clears up for me if I just reach under and drain the bowls. The suction of it draining usually fixes it. I have twin fuel filters so I still don't know how it gets in there, but the drain method has always saved me from having to pull the carbs.
1981 KZ750
One1 is offline
post #10 of 10 (permalink) Old 06-30-2018, 07:59 AM Thread Starter
cepak4772's Avatar
It acted up again on my way to work this morning, so I'll definitely give it a drain and blow back to to make sure. I'm not complete machine dumb just never wrenched on a bike and don't want to have to pull the carbs and screw something up and be out a bike till it gets fixed.
