ACCT QUESTION - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 06-16-2018, 02:57 PM Thread Starter
cepak4772's Avatar
ACCT QUESTION
I have a tick that sounds like it's coming from the right side. As per some advice given on here I removed the ACCT bolt and rotated the screw cw and ccw movement one way and good spring back and no movement the other way. I removed the bolt on the rear ACCT and oil began slowly oozing out if the hole. Is that a normal occurence. I haven't read that on any of the ACCT posts I have read so far.
Sent from my SM-G965U using Tapatalk
cepak4772 is offline
post #2 of 3 (permalink) Old 06-16-2018, 05:48 PM
Yes, it's normal to have oil there.
post #3 of 3 (permalink) Old 06-18-2018, 10:58 PM
It is such a common occurrence, sometimes those little details are left out. The downside of the rear Act is the angle. Any oil this trapped in there will come out when you release the screw. But no more should continue to drain out but for a few moments after the screw has been removed.
