Engine Painting Question.... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 03-22-2009, 05:51 PM Thread Starter
93VN750's Avatar
My engine is apart right now, both side cases off, both heads and cylinders off.
I am not sure if I should paint the engine in pieces, or wait until it is back together.
Anyone how has painted their engine, I look forward to your feedback.
Thanks!
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #2 of 7 (permalink) Old 03-22-2009, 06:01 PM
you want to paint the engine with as much of it together as possible tape off all openings such as exhaust ports, and carb ports... also tape off any thing that you don't want paint in or on
post #3 of 7 (permalink) Old 03-22-2009, 06:33 PM
The Professor
lance328's Avatar
Thanks!
Jon
I painted mine fully assembled minus the carbs, much easier than in pieces.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #4 of 7 (permalink) Old 03-22-2009, 07:03 PM Thread Starter
93VN750's Avatar
Looks like put back together it is!
What paint did you use?
Jon
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
Dunlop D-404's
93VN750 is offline
post #5 of 7 (permalink) Old 03-22-2009, 08:14 PM
The Professor
lance328's Avatar
Jon
Dupli-Color High Temp. Engine Enamel w/ceramic from Advance.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #6 of 7 (permalink) Old 03-22-2009, 09:05 PM
any engine enamel will will work...I prefer Duplicolor's engine paints... they withstand almost any abuse you can through at it...minus batt acid.
post #7 of 7 (permalink) Old 03-22-2009, 09:34 PM
black grill and stove paint works well too it is very high temp enamel,denny
