87 - neglected $30 bike - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 25 (permalink) Old 03-20-2009, 11:17 AM Thread Starter
For those of you who like inflicting pain on yourselves you will like this. 87 VN750A with 9900 miles. Looks like it was in a little fire some time in its life maybe as part of a left side tip-over then passed through several owners in between being parked outside.
Issues: haven't been able to get the motor to turn over cause the starter doesn't work - tried good 12 V to the starter pos terminal; not even a spark. I suspect the motor is burnt up from trying to crank a frozen motor. Will pull the starter to see if it's something repairable. May try pulling the plugs to see if I can turn it over with the rear wheel or by pushing it down a hill.
Also needs: complete headlight & lt ear, blinkers, radiator screen, fr tire, fr brake fix, seat cover, lt carb intake hose (this may have allowed water into the fr cyl), side covers, 1 air cleaner cover, and a tail light lense. That's all!
Name:	87 Kaw VN750.JPG
lrayvick is offline
post #2 of 25 (permalink) Old 03-20-2009, 11:39 AM
The Professor
lance328's Avatar
Pour a little trans fluid in the cylinders, it will free stuck rings.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 25 (permalink) Old 03-20-2009, 12:45 PM
Chucklehead
dragon159's Avatar
Okay ... Now I don't feel so bad. I thought mine was looking ugly.
"Squirrel Bike" aka Jersey
Rat bike with a good PR agent
shaved and coastered
2 into 1 exhaust
rear 170 and front 110
custom dash with voltmeter
Spitfire windscreen
Plutonium plugs
More to come
dragon159 is offline
post #4 of 25 (permalink) Old 03-20-2009, 12:56 PM
i have the seat cover f ya need it... i pulled it off mine when i did a different seat... all you would have to do is staple the cover in place.
bigrepp61 is offline
post #5 of 25 (permalink) Old 03-20-2009, 03:08 PM
Simple Solutions
seebeeare's Avatar
my ears arnt in the best shape but they are functional and ones not horrible, i found that they apear to be both the same just flop the brackets... if my ear shave works like i know it will i will let them go... give me a week or too to assess the situation and hit me up if u think u may want them im sure we can negotiate something out...
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
How To Test the Stator
seebeeare is offline
post #6 of 25 (permalink) Old 03-20-2009, 04:53 PM Thread Starter
Ah sweet success: Pulled the plugs - they were somewhat gassy/oily with a little water on one but no water puddled in the cylinders. Squirted some used motor oil in the cylinders but would not turn with the rear wheel. Got a push and popped it in gear on a downhill - broke right loose. Fixed the starter now she cranks. I think I'm gonna have a runner.
Next to check spark, and see if the carbs are any good as is.
Mike & Seebeeare - I'll pm ya.
lrayvick is offline
post #7 of 25 (permalink) Old 03-20-2009, 06:03 PM
It`s good to hear you got the cylinders freed up and the starter is cranking over. I hope you can get all the other stuff you need, and be on the road soon. I`m getting the itch to ride after seeing a few more bikes out up here every day. Come on damn leg, heal up so I can get out there! Good luck with the project.
post #8 of 25 (permalink) Old 03-20-2009, 06:13 PM
cm4cm5's Avatar
if you get it running half desent, pour some seafoam in the tank to clean up the fuel system.
it my even help the carbs, by eatting the gunk away.
Jeff Brooks
Owensboro KY
'94 Vulcan 750
cm4cm5 is offline
post #9 of 25 (permalink) Old 03-20-2009, 08:00 PM Thread Starter
Installed exhaust and got spark. Startin' to look like something but quite a ways to go.
Name:	87 Kaw VN750 2 sm.JPG
lrayvick is offline
post #10 of 25 (permalink) Old 03-20-2009, 08:40 PM
The Professor
lance328's Avatar
Contact Crobins365 she should have HL,ears, taillight, radiator cover and carb boot.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
