Random loss of power - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 3Likes
  • 1 Post By Thorn
  • 1 Post By Goofyfoot2001
  • 1 Post By One1
post #1 of 6 (permalink) Old 05-03-2018, 08:57 PM Thread Starter
Iíll be cruising along and all of the sudden the motor will just turn off but the lights on the dash and the headlight are still on. When it happens I pull the clutch in and press the start button and it starts up. Then itíll run fine after that. It did it three days in a row. Ran good for two days then did it again today. Has this happened to anyone else?
97 Kawasaki vulcan 750
2015 Honda CBR650F
Both all stock
Collyz85 is offline
post #2 of 6 (permalink) Old 05-04-2018, 01:03 AM
Sounds like you're losing power momentarily between the battery and the igniter box, essentially flipping the kill switch.
The ignition puck itself is a common source of problems similar to this. If a contact starts going bad it can break the circuit. You can either buy a new one, or open the old one up to clean and tighten up the contacts. There are a couple threads with instructions around.
WilliamTech3 likes this.
Vulcan slang for newcomers
Service Manual Download
Thorn is offline
post #3 of 6 (permalink) Old 05-08-2018, 10:33 AM
Clean ignition switch
post #4 of 6 (permalink) Old 05-08-2018, 08:43 PM
GDI
Could it be something silly like a loose ground wire?
GDI
GDI is offline
post #5 of 6 (permalink) Old 05-08-2018, 09:09 PM Thread Starter
Iíll try to get to the ignition switch this week. Hopefully thatís all it is.
2015 Honda CBR650F
Both all stock
Collyz85 is offline
post #6 of 6 (permalink) Old 05-09-2018, 01:01 PM
I'm a rider
One1's Avatar
Another vote on the switch, but be mindful of the wires going into the switch as well. If you clean and reassemble the switch, start the bike and try shaking and twisting the switch wires to see if there are any breaks.
1981 KZ750
1988 Vulcan VN750 (red)
2005 Vulcan VN750 (silver)
(2) 1994 Vulcan VN750 (red)
One1 is offline
