bunnies gorillas or clubmans? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
  • 1 Post By One1
post #1 of 9 (permalink) Old 04-12-2018, 04:45 PM Thread Starter
black coffee
chokingvictim's Avatar
Y'all Care to pick favorites?
Apehangers seem tricky to fit to a stock vn and drag bars left me feeling pretty scrunched up on the tank..
but six bend bars are finally making a comeback in the chopper scene! I wouldn't mind seeing more of those on vulcans!
2002 vn750
hocked goat
single carb
dope ass suicide shifter
hand clutch
emmisions axed
bitchin stereo
permanent trailer containing charging system
beer cooler backrest
chokingvictim is offline
post #2 of 9 (permalink) Old 04-17-2018, 01:55 PM
I'm a rider
One1's Avatar
Looks v/s comfort. The age old debate. I'm making a set that steps up instead of bending up. It gives a drag bar look, but comes up enough to get you off the tank.
Pick anything you want, measure it to fit your size, and I'll make it happen. I've been playing with spare pipe lately building a custom set for my fourtrax. I have 8 pie cuts in a pipe that is only 5 inches long and makes 2 bends on one of my earlier test pieces.
I don't like bending pipe and stretching it's grain structure. When welding, careful control of the heat affected zone and a series of pie cuts makes them as strong as a freshly make straight pipe.
1981 KZ750
1988 Vulcan VN750 (red)
2005 Vulcan VN750 (silver)
(2) 1994 Vulcan VN750 (red)
One1 is offline
post #3 of 9 (permalink) Old 04-17-2018, 02:26 PM
Alpha Geek
Hexadecimus's Avatar
I'm partial to rabbit ears. I was never a fan of the multi-bend bars or other chopcult hipster trends. I'm sure they're among the most comfortable though.
Hexadecimus is offline
post #4 of 9 (permalink) Old 04-17-2018, 03:47 PM
10" apes fit,and 12's are close,but i haven't tried all the cables with the 12's
post #5 of 9 (permalink) Old 04-17-2018, 08:03 PM
GDI
Huge fan of the mini-apes here. Did that on my last two bikes, but the stockers are working for me so not planning any changes this time.
GDI
GDI is offline
post #6 of 9 (permalink) Old 04-17-2018, 11:37 PM Thread Starter
black coffee
Hell yeah! If your ever in a pinch for drag bars copper water pipe 7/8 bolts right on for 3 bucks roughly.
Far as comfort goes I normally go 18 inch apes,it'll vibrate a watch off your wrist but beats all the pressure on your shoulders if you wind up slumped over the tank on some buckhorn bars
2002 vn750
hocked goat
single carb
hand clutch
emmisions axed
bitchin stereo
post #7 of 9 (permalink) Old 04-17-2018, 11:41 PM Thread Starter
black coffee
That sounds like a damn good time! you ever fool around with chain links at all?
2002 vn750
hocked goat
single carb
hand clutch
emmisions axed
bitchin stereo
post #8 of 9 (permalink) Old 04-17-2018, 11:59 PM
I'm a rider
One1's Avatar
Smaller links just burn up on me. Decent size seem to weld up well with the Tig. I've migged them, but don't get the fusion I want. With tig I can melt the base metal together without any filler and fuse it, then add as much reinforcement as i want. That way I can choose to hide the weld where you can't see any filler. My favorite is fusing them then adding silicone bronze in the links. Really jazzes it up to have the bronze inside the links.
Here is my practice tube I've been using to see how much I can manipulate it before it's noticeable that i welded it. I've cut this bare mid section in half and put it together 8 times, 1/3 of an inch apart each time.
Also, here is my silicone bronze cubes i make to practice heat control on small objects.
ID:	43802   Click image for larger version
ID:	43810   Click image for larger version
ID:	43818   Click image for larger version
ID:	43826   Click image for larger version
Thorn likes this.
1981 KZ750
One1 is offline
post #9 of 9 (permalink) Old 04-18-2018, 08:34 PM Thread Starter
black coffee
Well Damn! My welding techniques are just crude compared to that! You better throw up pictures of whatever you put together
2002 vn750
hocked goat
single carb
hand clutch
emmisions axed
bitchin stereo
