where to get parts gaskets ect.... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 26 (permalink) Old 03-13-2009, 01:03 PM Thread Starter
Simple Solutions
seebeeare's Avatar
i was curious if u have a particular site to get gaskets and parts and maybe a list of parts i'll need to split the cases, (all gaskets to get me up and runnin?) and the best place to get that shift rod, i was also thinking about replacing the dampener just cause im in there ive heard some horror stories....
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
How To Test the Stator
seebeeare is offline
post #2 of 26 (permalink) Old 03-13-2009, 04:00 PM
post #3 of 26 (permalink) Old 03-13-2009, 10:58 PM
CWO3 Navy (Retired)
cliffhusn's Avatar
I always use cheapcycleparts.com; they seem to have the lowest prices, great customer service, and low shipping costs.
The Flag on my bike honors those who serve our Country and those who have served!
cliffhusn is offline
post #4 of 26 (permalink) Old 03-13-2009, 11:01 PM
flitecontrol's Avatar
X2. Be sure to check with these folks.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #5 of 26 (permalink) Old 03-14-2009, 09:26 AM
dragonrider's Avatar
yep, cheapsysleparts.com is reliable i have bought many parts from them .
another site you can try is bikebandit.com. between the two you should beable to find what you need
dragonrider
ride long and ride safe
dragonrider is offline
post #6 of 26 (permalink) Old 03-14-2009, 11:16 AM
The Professor
lance328's Avatar
Gaskets needed:
2- Head Gaskets
2- Cylinder Base Gaskets
Left and Right side Case Gaskets
1- Bevel Gear Gasket
1- Oil filter Plate Gasket and the two o-rings
4- Coolant Pipe O-Rings (right pipe from water pump to case halves)
1- O-Ring that goes behind Impeller
1- Transmission cover gasket
1- Mechanical Seal (water pump impeller)
1- Tube of Yamabond or three bond case sealant (to seal the case halves) DO NOT use RTV silicone
1- Small tube of blue loctite for lower chain tensioners
1- glaze breaker or emory cloth to break the glaze on the cylinders "if you do not break the glaze the rings will not re-seat"
1- Clutch hub holder http://www.motosport.com/dirtbike/pr...segment=badger
1- Flywheel Puller http://www.repairmanual.com/motorcyc...4/0/4886/10471
ORDER PARTS FROM: http://www.cheapcycleparts.com/Street.aspx
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #7 of 26 (permalink) Old 03-14-2009, 03:44 PM Thread Starter
Simple Solutions
seebeeare's Avatar
oil filter plate? and mechanical seal (water pump impeller)
Breaking the glaze is a term im not familier with granted its a long ways away but juust trying to prep myself
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
post #8 of 26 (permalink) Old 03-14-2009, 03:56 PM Thread Starter
Simple Solutions
seebeeare's Avatar
thanks again lance i'll be ordering as soon as i get the word GO
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
post #9 of 26 (permalink) Old 03-14-2009, 03:57 PM
For lack of a better term, the ring movement forms a "glaze" on the cylinder wall. If you don't remove it, the new rings won't seat. Glaze breaker is a rotary hone with three spring loaded arms with fine stones on the end. Mounts in a drill. Use a variable speed drill on low to medium speed and move it up and down the cylinder wall at a constant speed. Will polish the walls and remove the "glaze". Can probably google rotary hone and see a picture of one. Some auto parts places loan 'em out.
"Black Beauty"
Old Blue
post #10 of 26 (permalink) Old 03-14-2009, 05:01 PM Thread Starter
Simple Solutions
seebeeare's Avatar
i dont plan on re ringing it can i pull the heads with the pistons and skip this step?? just thinking i know im not the one with the experiance here so it was just a question...
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
