Posts that should be "stickies" - Page 2 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Suggestions / Tech Support / Site Help Having technical problems with the forum?
Can we make the site any better? Have a suggestion? Let us know.
Testing Grounds - <<-- Test your signatures and avatars here
post #11 of 15 (permalink) Old 10-19-2012, 09:36 PM Thread Starter
...link me, bebbay, so's I see the exact one ya mean...think I know, but wanna be sure. Might merge 2 even if not the same. Actually, found it...let it go for now so that a few more facts can be added and docs presented...too early in the thread.....when it grows some, then I will. K ?
post #12 of 15 (permalink) Old 10-19-2012, 09:40 PM
Thread: Shindigen FH020AA by Kelly2001
Could you make the Mosfet Testing Procedures a sticky ?
WilliamTech
JM2001
Here is the Mosfet FH020AA diagnostic check from Roadstercycles: I quote: Multimeter on diode check.
Positive multimeter lead to positive mosfet pin, negative multimeter to each stator pin 1 at a time, should get all zeros.
Negative multimeter lead to positive mosfet pin, positive multimeter to each stator pins 1 at a time should get all close to the same, about 100, I've seen 70 to 140 depending on ambient weather (still all good).
Now, Positive multimeter lead to negative mosfet pin, negative lead to each stator lead 1 at a time should get 435 ish all close to the same (again varies by ambient temp).
Negative multimeter to negative mosfet pin, positive multimeter to each stator pin 1 at a time, should get zeros.
If you get a zero where you should not or a number where you should not, then you possibly have a bad mosfet, odds are not good of that." End quote
__________________
JM2001
" Loud Pipes Risk Rights "
post #13 of 15 (permalink) Old 10-19-2012, 09:43 PM Thread Starter
When someone gets positive results from the info...consider it stuck.
post #14 of 15 (permalink) Old 10-19-2012, 09:47 PM
Arrow
thanks
WilliamTech
post #15 of 15 (permalink) Old 10-19-2012, 10:38 PM Thread Starter
NP brother...Semper Vigilante !...thanks !
