Need Fuel Line diagram - Page 2 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Go Back   Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums > Technical Forum > Carbs and Fuel System
Thread Tools Display Modes
  #11
Old 09-05-2008, 01:28 AM
bullwinkle's Avatar
bullwinkle bullwinkle is offline
Addicted to Projects
bullwinkle is on a distinguished road
Sorry it took so long for me to get these for you but here is how ithe choke cable is run through the carbs on my bike:
Anything else I can do please let me know (I promise to get it done quicker next time)
__________________
Charlie
VN700 project bike 98% completed!!
68 Bushwhacker this winters project (in the works)
86 Honda GL1200i (winter project #2)
82 kz440 daily rider for now!
A few clowns short of a circus now aren't we?
Old 09-06-2008, 04:55 PM
guitar99 guitar99 is offline
guitar99 is on a distinguished road
Fule lines and Choke cable front brakes
All,
I just fixed a wire problem that caused the bike to die. Right before that happended I test drove it and that's when the Fuel leaked all over and we also have a Radiator leak. If anyone can get a a picture or diagram where the three fuel lies go (From the Petcock) to the Carb.. That would so be helpful. We don't think our reserve line is in the right place if at all hooked up.
Should it not go back into the Tank? The link that comes out of the "T" at the bottom of the Petcock goes straight down onto the Carb nibble. I marked that one from before removing the Carb. In fact, I marked all the lines but the other two just rubbed off. Also, before pulling the Carb, I unhooked the
Choke cable but now having the carb back in it's tuff to see or find where that
Choke Barrel on the end of the cable hooks into. Also, someone said the new throttle cables are not on exactly right. Anyone have a pic of throttle cables as well. Resolving these should get us running except for bleeding the
front brakes. We got a new (Used) Master Cylinder but can't manually bleed the brakes. Can't bring pressure to the Master Cylinder and get the Banjo bolt installed air tight. We tried a Brake Bleeding kit but seem to need reverse bleeding. Is there anyone in the D.C. Virginia area that works on these bikes ?
Thanks
David and Andrew
  #13
Old 09-06-2008, 04:58 PM
Charlie,
This is awsome! So helpful! I just had to troubleshoot a Wire problem so seeing this is like new Hope! So helpful! Thanks so much! Have a drink on me!
  #14
Old 09-06-2008, 05:00 PM
Charle,
Thanks again! This is so helpful!
David and Andrew
  #15
Old 09-06-2008, 09:00 PM
bullwinkle's Avatar
guitar99,
There are several pictures in the manual, you can download the manuel from:
http://www.tocmanufacturing.com/File...nd%20Parts.pdf
This is a very big Adobe file, it contains a parts list for all years of the vn700 & 750. Save it to your hard disk so you don't have to download it every time you want to view things.
On page 2-8 shows the area at the end of the choke cable
On page 2-14 it shows another pic of the end of the choke cable
Page 2-18 shows the routing of the hoses of the carbs
Page 2-25 shows pic of fuel petcock
Let us know how we can help
__________________
Charlie
  #16
Old 09-09-2008, 05:35 PM
CMess CMess is offline
CMess is on a distinguished road
Send a message via Yahoo to CMess
Choke cable runs down the left side of the bike then through the middle of the carb there is a metal bracket which is a triangle holder. It holds the end of the cable housing.
  #17
Old 09-09-2008, 05:39 PM
Let me know if you need pictures still I will do the bast I can... I just spent all summer getting my 85 running.
  #18
Old 09-09-2008, 06:38 PM
CMESS,
I do need a picture or to know exactly where the hoses on the petcock
go. I pretty sure the one going straight is vaccume and goes to the close
Nipple on the carb. The two Gas lines ??? Which one where?
Also, there is a Black Plastic "T" that we are still trying to make sure
the Vaccume Hoses go to the right place... We have one that is missing.
  #19
Old 09-09-2008, 07:40 PM
Old 09-09-2008, 07:42 PM
You may not post new threads
You may not post replies
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
