Final Drive leaking small amt of Gear Oil - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Go Back   Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums > Technical Forum > Transmission / Rear End
Chattering Clutch? Transmission Trouble?
Thread Tools Display Modes
  #1
Old 06-16-2010, 11:07 AM
Wilkman Wilkman is offline
2005 Silver
Wilkman is on a distinguished road
Send a message via Yahoo to Wilkman
I have a 2005 with 22K and I have noticed after doing some more hi-way riding I have a small coating of gear oil on the rear wheel hub. Looks as if it has been drawn out past the seal by centrifugal force. There is no leak puddle after the bike has sat parked for a week. I wanted to find out if this is normal or a sign that a seal is in need of replacement? I can post some pics if no one has seen this before. But with the experience I have seen in this group I doubt that
Old 06-16-2010, 04:38 PM
Gemguy's Avatar
Gemguy Gemguy is offline
Gemguy is on a distinguished road
I had the problem with my 2003, as many of us here have as well, but it finally got fixed after 2 tries. I bought the big O ring and a cardboard inner seal and had them put in but the most important component is to be sure to use Honda Molly 60 grease in the hub. If you use anything else it will ultimately leak out. Also while you're there make sure to lube the splines. Good luck.
__________________
~VROC~ # 389
  #3
Old 06-16-2010, 04:51 PM
2005 Silver
Thanks, Kind of where I was headed after reading some other posts. I did read the Spline lubing posts and wanted to make sure I did that if i had to dig in there.
You don't happen to have those Part numbers handy for the O-ring and gasket. I found O RING Part #671B25145 but don't see a cardboard seal on the parts diagram.
Thanks Again
  #4
Old 06-26-2010, 03:33 PM
kay kay is offline
carbon unit
kay is on a distinguished road
I disagree. Because I have used something else and have put more than 2000 miles on the bike without it showing up on my wheel. And others have admitted to the moly 60 being slung out by centrifugal force because they used a bit too much.
I also replaced my large oil-seal [92049-1234] and it did leak a small amount of gear oil after doing so for like the first 200 miles. But now my dif case holds it's oil just fine.
__________________
There's nothing like having the time to sun yourself on the hood of an old truck, on a cool day.
  #5
Old 06-26-2010, 05:38 PM
slimvulcanrider slimvulcanrider is offline
slimvulcanrider has a spectacular aura aboutslimvulcanrider has a spectacular aura about
Kay, what did you use in place of the honda moly grease?
  #6
Old 06-27-2010, 03:11 AM
kay kay is offline
carbon unit
VALVOLINE SYNPOWER GREASE
Character: Molybdenum Disulfide, Rust and Oxidation Inhibited, Extreme Pressure Fortified
and I'm using Valvoline VV824 High Performance Gear Oil SAE 85W140 for the final drive dif
__________________
  #7
Old 06-27-2010, 09:49 AM
thanks for the info Kay
Old 07-24-2010, 01:06 AM
warmsound's Avatar
warmsound warmsound is offline
warmsound is on a distinguished road
Hi,
I also notice over the last two days what looks like small leaks on my rear hub. I didn't have this problem earlier. It just started appearing. I did have the rear tire changed and spline inspection done about a week ago.
Is this more of a seal problem or does it have to do with the brand of oil and how much?
__________________
WarmSound
They made them cool in 02!!!
2002 VN750
  #9
Old 07-24-2010, 08:17 AM
KIMMERLING's Avatar
KIMMERLING KIMMERLING is offline
KIMMERLING is on a distinguished road
Mine comes out but i loaded it to the max with moly 60...and it gets hot here.
__________________
Ventura guards
MadStadt mount
Givi windshield/Heated grips
Backoff
Riderbeads
Givi 52 topcase
OEM centerstand
Headlight modulator
Battery tender
  #10
Old 07-24-2010, 01:25 PM
baldy's Avatar
baldy baldy is offline
baldy is on a distinguished road
I think some are confusing where the oil/grease is coming from. As I see it ..it is coming from around the dif housing where it attaches to the wheel. If so that seal needs replacing after oh say 15 to 20k. My 93' that had 19k when I bought it was already leaking and I have replaced the seal twice with 45k on it now. My 01' that had just under 7k when I bought it and now has around 15k is now starting to develop the leak. If it is minimal don't worry about it and keep the rim and tire clean and the final drive full, but it will get worse so have the parts/seals on hand to do it.
__________________
01' VN750
Jardine cross over exaust
Kyriakin grips and foot pegs
Modified seat and backrest
Luggage rack
Spline lube
93' VN750 getting TLC
Decals and mirrors
ACCTs to MCCTs
Degoated with Harley mufflers
Pick-up coils at .020
Spline lube
Tags
final drive, gear lube, gear oil, leak
You may not post new threads
You may not post replies
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
