Oil Leak Issue - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
Go Back   Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums > Technical Forum > Engine / Exhaust / Cooling
From the radiator, through the case and out
Thread Tools Display Modes
  #1
Old 04-21-2010, 02:50 PM
New Vulcan Rider New Vulcan Rider is offline
New Vulcan Rider is on a distinguished road
Oil Leak Issue
Hey All, I just recently bought an 89 Vulcan 750. I really know nothing about auto mechanics, but I'm learning.
My issue is I have a pretty big oil leak-I believe it is coming from the rear portion of the bottom of the bike (like toward the rear of the crank case and near the coolant reservoir; at least that is where the majority of the oil seems to be). I think it might be a leak in a gasket in the engine cover. It did give me some white smoke one time-but hasn't done it in a few starts since (so I guess it could be the head gasket, but I'm hoping it isn't). Any insight? Ideas where to start?
Thanks!
Old 04-21-2010, 03:11 PM
flitecontrol's Avatar
flitecontrol flitecontrol is offline
flitecontrol will become famous soon enough
Clean off all the oil and watch it closely to see if you can pinpoint just where it's leaking.
__________________
"Black Beauty"
Currently 23,298 miles
Old Blue
  #3
Old 04-21-2010, 05:22 PM
fergy's Avatar
fergy fergy is offline
fergy will become famous soon enoughfergy will become famous soon enough
One thing comes to mind. Behind the coolant bottle on the back of that cyl jug is where the automatic cam chain tensioner is located. If it is loose, or if it has been replaced with a manual cct and not done right, you'll get quite a bit of oil dribbling out of there. ACCT's and MCCT's look completely different.
Manuals look like a bolt head with a locking nut on it, protruding from the engine case.
The ACCT's look like an enclosed device with a small 6mm screw on the very top.
Just something to check out.
__________________
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
  #4
Old 04-24-2010, 01:57 AM
Fergy, Thanks for the advice. There's a good chance that the cam chain tensioner is where the oil is coming from. I'm replacing the o ring located inside of the foremost bolt and I'm going to make sure both side bolts are tight. Any other advice?
It seems like that is the best guess other than the possibility of the engine side cover gasket needing a replacement. Thanks for the direction. I'll let you know how it turns out.
  #5
Old 04-24-2010, 07:30 PM
Well it wasn't the cam chain tensioner o ring. After replacing it, I cleaned the bottom of the crankcase and the entire bike, then ran it for about 17 miles. I found that the leak is really streaming from the bottom side engine cover bolt closest to the coolant reservoir. It makes sense bc my tire was getting large amounts of oil on it and with the leak in that location, it would slide down the center stand right to my rear tire.
With that said, any pointers on replacing the gasket between the side cover and the crankcase?
Thanks!
  #6
Old 04-24-2010, 11:55 PM
lance328's Avatar
lance328 lance328 is offline
The Professor
lance328 has a spectacular aura aboutlance328 has a spectacular aura about
Send a message via Yahoo to lance328
Thanks!
Remove the spark plug wells and replace the O-RINGS!!! The right rear and left front have deep spark plug caps they go inside the "plug well" When the O-ring goes bad you will get oil comming out of the drain hole.
Insert a large hex nut to fit in the recessed hex on the plug well and remove w/cressent wrench. If you have an ACE Hardware near you match them up with new ones, if not order from KAW.
__________________
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
You may not post new threads
You may not post replies
Powered by vBulletin® Version 3.8.5
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
