CCT - Convert or replace? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 4Likes
post #1 of 33 (permalink) Old 04-04-2017, 03:00 PM Thread Starter
I'm overdue for a CCT fix and was wondering if it's worth buying aftermarket MCCTs or if converting the ACCTs will give as good a result.
On a similar note. Is there any risk to converting the ACCTs? Wouldn't want to mess them up and have my bike down for weeks waiting for replacements.
Biking Viking is online now
post #2 of 33 (permalink) Old 04-04-2017, 03:47 PM
Retired USAF (IYAAYAS)
Chris and Shim's Avatar
I converted. My TOC MCCTs are bullet proof.
'06 model
Saddlebags, hard mounted
Fork mounted tool bag
Relocated rear turn signals
LED turn signals, brake lights and running lights
LED license plate frame
Engine Guard and Highway pegs
Plexifairing III windshield
Custom seat (made by a local guy)
Iridium plugs (DPR7EIX-9)
Shenko 230 Tour Master tires at 11,123 miles
Splines lubed at 11,123 miles
Luggage rack
Dash Board
Chris and Shim is offline
post #3 of 33 (permalink) Old 04-04-2017, 04:30 PM
I converted the ACCT's and have had them on for about 2 months and 500 miles or so. (Not really a testament to longevity yet, but I'm happy and the engine doesn't clatter on startup like it used to) Teflon tape the threads so you don't leak oil if you do the conversion.
ubertalldude is offline
post #4 of 33 (permalink) Old 04-04-2017, 08:02 PM
my DOC MCCT's have lasted at least four years
earshaved
BOO
BRING BACK WOLFIE.
"I only carry when I have my pants on"Joe Robinson aka Old Dog
OleDirtyDoc is online now
post #5 of 33 (permalink) Old 04-04-2017, 08:27 PM
If you are a worry wart or have cash to burn buy the TOCs and enlist someone you trust to help adjust properly. If you are cheap and prefer the pride of DIY make your own and use the wolfie mod from sticky and pat yourself on the back.
If I can do it, anyone can. Adjusting them is harder than making them. In my opinion if you are nut adding the nut internally you should not modify stock acct - I would not trust them without the aforementioned welded nut inside. YMMV.
2002 vn750
AGM battery, Shinko 230 tires oversized front
Ear shaved - k&n pods, drilled clutch basket
40/138 jetting
If I can split a case and make it work - you can too!
Forum pictures:http://s150.photobucket.com/user/Gid...?sort=3&page=1
gidaeon is offline
post #6 of 33 (permalink) Old 04-04-2017, 09:27 PM Thread Starter
Is it even possible to weld? It's aluminium, right? Aluminium welding is very much outside my comfort zone.
post #7 of 33 (permalink) Old 04-04-2017, 09:30 PM
I meant JB weld sorry I wasn't totally clear
gidaeon is offline
post #8 of 33 (permalink) Old 04-04-2017, 09:42 PM
https://r.tapatalk.com/shareLink?url...4&share_type=t
my acct to mcct conversion(not mine,actually)
read this
earshaved
BOO
BRING BACK WOLFIE.
post #9 of 33 (permalink) Old 04-05-2017, 11:42 AM
read this
After reading through that post I am definitely going to take my converted ACCT's out and install the JB-welded nut as is discussed in that thread before I go riding again.
post #10 of 33 (permalink) Old 04-05-2017, 01:57 PM Thread Starter
JB weld is only available in the US AFAIK.
Is it just 2-component epoxy, or is it different in some way. I always assumed that Americans just refer to it because it is the most common brand (like post-its).
So, will any 2-component epoxy do?
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
