Ear Shave/Air box Removal Loose Breathers - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
  • 1 Post By michiganteddybear
post #1 of 3 (permalink) Old 02-14-2017, 04:16 PM Thread Starter
I have an 05 and I'm in the process of removing the ears and air box. I can tidy up all of the loose hoses to the air box (cap on right side vacuum port and coaster install). However, the small tube on the right and the larger breather tube on the left that attach to the front nipples on the air box right behind the radiator have me confused as to what they are and how to plug them.
I don't have a pic of the one on the right. What is it and should I plug it/remove it?
Here's a picture of the left side one that comes from the engine. Is this a crankcase breather? How would you/should you plug it?
snowman4839 is offline
post #2 of 3 (permalink) Old 02-14-2017, 04:31 PM
yes, crankcase breather, dont plug it, put a small breather filter on it.
jgs000 likes this.
33.5k and counting
original stator (as far as I know)
ear shave, using Uni pod filters.
Pickup coils at 0.020 gap
VN900 seat mod
led's turns front and rear
MOSFET R/R, mounted under left side cover
2-wire mod to bypass clutch/neutral nanny switches
removed side stand switch.
post #3 of 3 (permalink) Old 02-14-2017, 06:00 PM
For the crankcase breather, you can put a filter in the hose right there, or run a longer hose farther up. I slid a smaller fuel hose inside the larger hose and clamped it with the stock wire clamp, then mounted the filter where the right ear was. Most parts stores have the filters now. Round, cone, colors, or chrome.
The small hose on the right sounds like the condensate drain for the airbox, so it can be removed.
2003-19k mi
Me and Cinderella, we put it all together, we can drive it home, with one headlight.
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
