Hydraulic lifters soak or not soak ? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 09-29-2016, 05:07 AM Thread Starter
Hi guys
A lot of videos on Youtube says, that it is important to bleed the hydraulic lifters in oil until no airbobbels come out and the piston is stone hard.
But on this video the guy says, that it's a bad idea. Much better to let the oilpressure from the engine pump up the lifters:
What is your opinion ?
Regards
Preben
Preben59 is offline
post #2 of 3 (permalink) Old 09-29-2016, 05:19 PM
I tore down my engine completely a few months ago (there's a very long thread) and I skipped that part as was done in roach's vids. Count me in the No camp. I did plenty of priming of course later. almost 3k miles later - no issues. I do have a slight tick from the top end that may or may not be lifter noise after my wolfie DIY mcct upgrade post rebuild.
Another member and respected pro. mechanic on here I trust advised I didn't have to soak\bleed in my scenario. Yes I had them removed, upside down etc., before reassembly. YMMV
2002 vn750
AGM battery, Shinko 230 tires oversized front
Ear shaved - k&n pods, drilled clutch basket
40/138 jetting
If I can split a case and make it work - you can too!
Forum pictures:http://s150.photobucket.com/user/Gid...?sort=3&page=1
gidaeon is offline
post #3 of 3 (permalink) Old 09-30-2016, 06:13 PM
I think flushing them was the point Roach made.
You flush them with kerosene to clean them out, but I don't recall him pumping oil into them before install....but I could be wrong.
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
