After the other day I have decided to flush my cooling system. I bought some prestone stuff good for aluminum engines and ran straight water through first. Now, my bleed screw is almost stripped, so rather than take the chance I just ran the bike with the radiator cap off. I got quite a few bubbles and when I revved the bike the water would shoot right out the cap hole. Is this normal, or I am thinking I know why I have a hot running bike as I am suspecting a head gasket leak now.
Ive changed the thermostat. The fan works. In fact now the bike is running cooler and the fan turns on sooner. Im thinking the cleaner stuff really may have worked. The. Ike would run all the way to red. Now its running halfway like it used to. I can see the needle drop when the thermostat opens. So i will run a couple more days then replace the coolant. Hopefully i got it.
I have drained my coolant from my cooling system and refilled it many times.....and I have never once used my bleeder screw. I just fill my coolant overflow up to a little over the full mark and add coolant to the cooling system at the radiator/system cap till it's full then squeeze the fat "L" shaped radiator hose at the bottom of the radiator to get some of the air out of the system. Then top off again. After I warm the engine up to running temp and the thermostat opens and I let the system cool back to ambient temp I take off the coolant system cap and add coolant to top off again.....then check overflow tank level. This is "my" procedure and I have never had one issue with air in the system. I also only use distilled water and water wetter with about 15 to 25% green antifreeze added in.
Thanks for the tip Brett. My 12 mile ride home in 88 degree weather wasnt so good. It got to about a eighth of an inch from the red. Drats. I will run the cleaner a couple more days. I had a few traffic lights on the way home so that didnt help. Still a little better than last week.
If you keep having trouble and rule out the thermostat being the problem.....Take the radiator off the bike and put a garden hose in the radiator top hose port and the water should flow out the bottom hose port without water backing up at the top port and overflowing back out.....If this does happen......your radiator is seriously clogged.
Not sure if this will help any, but when I flush my radiator I put a gallon of vinegar in the radiator, crank the bike and let it run for about 10 minutes, drain the vinegar, refill the radiator with straight water, crank the bike up for about 10 minutes, drain the water then run water through the radiator to remove any residual vinegar. I then put in a gallon of Engine Ice.
Thanks. I am suspect of the radiator which is why I tried the flush / cleaner solution. I may take the radiator off and bring it to a local radiator shop to see if it can be dipped. Other wise i'm gonna look for another used one. The bike is a 1985 so its probably due.
Related Threads
Kawasaki VN750 Forum
411.9K posts
42.2K members
Since 2000
