Need Fuel Line diagram - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 23 (permalink) Old 08-24-2008, 11:49 AM Thread Starter
We are restoring a 1985 Vulcan 750.
We need to know where the fuel lines go.
In particular there are Two lines that come off the Black, Plastic "T" bar and one of our lines is missing. We also have a fuel like from somewhere (Likely that line). Someone said it was just a vaccume line but we really need
a Good Diagram. If someone that has a Vulcan 750 or better yet a 1985 we would appriciate knowing where the fuel lines go to. We do have the clymer's manual but it does not show this line.
guitar99 is offline
post #2 of 23 (permalink) Old 08-24-2008, 01:01 PM
Crobins365's Avatar
See my response to your other post - you can also check the "Carbs and Fuel" section of the Forum and find "Carb photos parts labeled" or whatever I entitled that thread. The T is the point from which the vent lines hook up from each carb, and then the last line off the T should take a vent line out to the RH airbox. Cut this last line at a 45-degree angle to keep it from bottoming out in the airbox.
C
Crobins365 is offline
post #3 of 23 (permalink) Old 08-24-2008, 02:43 PM
Addicted to Projects
bullwinkle's Avatar
guitar99
I have my carbs pulled from my 85 - 700, I can get some pics if you want.
Charlie
VN700 project bike 98% completed!!
68 Bushwhacker this winters project (in the works)
86 Honda GL1200i (winter project #2)
82 kz440 daily rider for now!
A few clowns short of a circus now aren't we?
bullwinkle is offline
post #4 of 23 (permalink) Old 08-24-2008, 03:03 PM
ChrisC's Avatar
Here are a couple of pics of the left side carb. One is viewed from the left side of the bike, and the other from the right side. The carbs are the same on both sides. Hope this helps.
Name:	Left Side Fuel Line View From Left Side.jpg
ID:	1001   Click image for larger version
Name:	Left Side Fuel Line View From Right Side.jpg
Chris
Wayne, NJ
1989 VN750-A5
VROC #27781
-MF Battery
-De-Goated/Re-goated
-Coastered
-Splines Lubed
-Stebel Nautilus Horn
-AutoMeter 2" VOM
-Silverstar Headlight
-Plexifairing III
ChrisC is offline
post #5 of 23 (permalink) Old 09-01-2008, 07:47 PM Thread Starter
Chris,
That would be awsome.. We had gas spilling out from a test ride.. so that would be helpful...
guitar99 is offline
post #6 of 23 (permalink) Old 09-01-2008, 07:49 PM Thread Starter
Chris,
These pic's are really helpful.. Can you get one as to where the
Choke Cable goes? The Choke was pulled off when the Carb came out
but did not get back in place.
guitar99 is offline
post #7 of 23 (permalink) Old 09-01-2008, 07:50 PM Thread Starter
Charlie...
guitar99 is offline
post #8 of 23 (permalink) Old 09-01-2008, 07:50 PM Thread Starter
Charlie,
Can you take a pic of where the Choke cable goes... ???
guitar99 is offline
post #9 of 23 (permalink) Old 09-01-2008, 11:46 PM
ChrisC's Avatar
Originally Posted by guitar99 View Post
Chris,
Just got back from a long weekend up in Maine. I'll try to get a pic or two tomorrow.
Chris
Wayne, NJ
1989 VN750-A5
VROC #27781
-MF Battery
-Coastered
-Splines Lubed
-AutoMeter 2" VOM
-Plexifairing III
ChrisC is offline
post #10 of 23 (permalink) Old 09-02-2008, 05:55 AM
bullwinkle's Avatar
Sorry been away for a while, will try to get some pics after work (it will be late evening for you) Darned Alaska time zone!
Charlie
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
