Carb Rebuild Kit - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 05-13-2009, 03:41 PM Thread Starter
skalding's Avatar
Carb Rebuild Kit
Has anyone found a carb rebuild kit for our bikes? I know some other machines use our carbs.
Basically I just need the 4 O-rings, but I don't like the idea of paying $20 odd dollars plus shipping for them.
Scheherazade
'86 VN750
MF Battery, Iridium Plugs, RR relocated, Voltmeter, 170/80/15 Kenda Kruz rear tire, DIY Samsonite hard bags, DIY shaved seat with Beaded seat pad ('cause that's how I roll) and the dreaded STATOR CHANGE.
Shining Black Bess '86 VN750, retired for parts after a fried stator and being knocked (kee-runch) in her parking spot.
skalding is offline
post #2 of 14 (permalink) Old 05-13-2009, 03:54 PM
The Professor
lance328's Avatar
No kits, you will have to bite the bullet.
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #3 of 14 (permalink) Old 05-13-2009, 04:33 PM
dirtrack650's Avatar
Go to ACE hardware.
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #4 of 14 (permalink) Old 05-13-2009, 04:39 PM Thread Starter
skalding's Avatar
hmm. That's a thought. Anyone know the Oring diameters off hand? The online just list "O-rings". One's kind of angular, but maybe a hardware store would have the big round ones.
Scheherazade
'86 VN750
skalding is offline
post #5 of 14 (permalink) Old 05-13-2009, 05:59 PM
Go to ACE hardware and take the o-rings with you. They should have a hanging wall like shelf of clear plastic bins with o-rings. Just match them up. I just did that recently for some o-rings around the coolant tubes where they go into the heads/cylinders and again for th o-rings under the gas cap.
If I had known about that earlier I could have saved a lot of time, money, and miles to the stealerships.
Chiron is offline
post #6 of 14 (permalink) Old 05-13-2009, 08:09 PM
The Professor
lance328's Avatar
You will not be able to get the Carb. o-rings anywhere but kawasaki or Keihin, they are not standard o-rings.
The float cover o-ring cross section is square not round, and the jet cover o-ring is molded to shape.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
post #7 of 14 (permalink) Old 05-14-2009, 09:28 AM Thread Starter
skalding's Avatar
Way to crush my dreams dude.
(Just kidding - thanks for sparing me a pointless trip.)
Scheherazade
'86 VN750
skalding is offline
post #8 of 14 (permalink) Old 05-14-2009, 02:19 PM
supasamurai's Avatar
When I was hunting for a rebuild kit, I couldn't find crap. I found one company that said that if I shipped my rubber out to them, they could match them. I also found kits for the air cut off valve. But no regular carb rebuild kits. I called a local dealer and they said that they could get a carb, but they wouldn't order it unless I came in to order it and then it would be 5-7 days. So I don't know what they have or if they even really had one. I realized that there were some actual broken parts on my carb though, so I ended up just getting a used carb on ebay and it works great! Cost me $150 plus shipping.
supasamurai is offline
post #9 of 14 (permalink) Old 05-14-2009, 06:27 PM
Newb with a Bullet!
krebsne's Avatar
Anyone know what other bikes use these carbs? Maybe we could get kits under another name or something. Seems odd for as common as these carbs are that kits aren't available.
krebsne is offline
post #10 of 14 (permalink) Old 05-14-2009, 07:52 PM
The arctic cat 400 (I think) uses keihin cvk34 carbs, but they've got a regular float bowl on them that opens horizontally rather than the vertical split we have. It may be that that's a one cylinder motor also. I think that's it. I had one guy offer to help me convert to mikuni carbs, but he never wrote me back. It's essentially getting a similar size mikuni and then rejetting it.
I'd also be interested in finding out if you could use a larger single carburetor and just fit a t between the cylinders. That way you could shave it down to just one air filter etc... But I don't know if that's feasible.
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
