LED rear turn signals - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
  • 1 Post By OleDirtyDoc
post #1 of 6 (permalink) Old 02-16-2017, 09:42 PM Thread Starter
lVluffin's Avatar
I just got these in today, wired them up, and can't get them to light. I hear that you don't need a [new, led specific] relay switch unless you go full led, so unless I've got them wired backwards, idk what it could be.
LED Turn Signal Indicators Screw Bolts Fits Jeep TJ CJ JK YJ Wrangler (Amber) (Pack of 2)
https://www.amazon.com/dp/B01G624QY6..._bqLPybZWAC41S [edit]
ID:	35450   Click image for larger version
ID:	35458   Click image for larger version
ID:	35466   Click image for larger version
lVluffin is offline
post #2 of 6 (permalink) Old 02-16-2017, 10:45 PM
EP34 is the correct relay
earshaved
BOO
BRING BACK WOLFIE.
"I only carry when I have my pants on"Joe Robinson aka Old Dog
OleDirtyDoc is online now
post #3 of 6 (permalink) Old 02-16-2017, 11:21 PM Thread Starter
lVluffin's Avatar
Excellent, thank you. Will this work with the stock lights on front? I'm getting in another, different led set for the front, though I don't if they'll function as running lights, so I'll have a full led set soon, but if these front ones on won't work I may have to keep the stock ones for a bit longer.
lVluffin is offline
post #4 of 6 (permalink) Old 02-16-2017, 11:26 PM
yes should work with stock lights on front
lVluffin likes this.
earshaved
BOO
BRING BACK WOLFIE.
post #5 of 6 (permalink) Old 02-17-2017, 06:57 PM
The relay should not prevent the LED's from working, but the timing of the blinkers would be too fast....just saying.
Did you try to reverse the leads on the blinkers? Unlike incandescent bulbs, LED's do have polarity and need to have positive on the correct lead.
post #6 of 6 (permalink) Old 02-17-2017, 08:04 PM Thread Starter
lVluffin's Avatar
turns out i had the left one wired backwards, i mistakenly assumed the black wire was ground, without looking up a diagram (TIL the colored line wires are the grounds on the rear turns) and the other was just plain-old defective(poor solder job, plebs ). so hopefully the seller will just send me a replacement, these things are so cheap its not worth the trouble to return ship.
got the good one to light though, the new relay was a perfect plug and play, and if i must say so, an even more satisfying click sound ;D thanks so much for the help, i really appreciate it. the mechanics im down with, but circuits are magic to me. if anyone is interested, i may post a thread in the custom mod/fab section, hell i may anyway as little action as we get around here. thanks again!
ID:	35481   Click image for larger version
lVluffin is offline
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
