Turn signal problem - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 6Likes
  • 2 Post By michiganteddybear
  • 1 Post By OleDirtyDoc
  • 1 Post By Nickdwhit
  • 2 Post By Dfroe850
post #1 of 9 (permalink) Old 02-06-2017, 11:15 PM Thread Starter
Hey all, thanks in advance for any help. This is my first bike and I'm by no means a mechanic or an electrician but I like to try myself and learn with help when I can. I have an 05 I'm having an issue with my turn signals. My left turn signal bulb was blown when I purchased my bike and the bulb had been stuck so I recently tried to pry it out which in turn messed up the housing to where a new bulb would no longer stay in place. The bike has the stock front but after market rear lights both incandescent bulbs. The right side works fine when switching on lights up, blinks regularly but the left side makes a buzzing sound and the rear bulb stays lit. I figure it's telling me the front bulb is blown. So seeing as I can't put a new bulb in the front left I just bought new LED front turn signals.
This is the issue....
I hooked the new front left LED turn signal up. The running light comes on but when I switch the blinker on it makes that same buzzing noise and the rear stays lit just like before. The stock right front is still connected at this time still and works as it should so I'm confused as to what might be the issue.
Just to see what would happen I connected the new LED right side signal (the working side) and the same thing happened...running lights but when switching on buzzing noise and rear signal stays lit.
I've read on some post it could be I need a new relay? Or possibly a grounding issue? But it's hard deciphering as my problem doesn't seem the same as most of what I'm reading nor do I really have any idea how one goes down the path of fixing those solutions mentioned. Tomorrow I'll be working on it and can upload pics of what I'm doing if need be. Thanks again!
Dfroe850 is offline
post #2 of 9 (permalink) Old 02-07-2017, 08:56 AM
led's dont draw enough current to properly operate the stock flasher unit. hit up the local car parts store, and get an EP34 (I believe that the right number). plug and play replacement for our stock flasher unit, but its solid state, so it will work regardless of the load
OleDirtyDoc and Spockster like this.
33.5k and counting
original stator (as far as I know)
ear shave, using Uni pod filters.
Pickup coils at 0.020 gap
VN900 seat mod
led's turns front and rear
MOSFET R/R, mounted under left side cover
2-wire mod to bypass clutch/neutral nanny switches
removed side stand switch.
michiganteddybear is offline
post #3 of 9 (permalink) Old 02-07-2017, 09:35 AM
NIBiker's Avatar
Or fit inline resistors to the value of the resistance of the original bulbs!
Sent from my HTC One_M8 using Tapatalk
NIBiker is offline
post #4 of 9 (permalink) Old 02-07-2017, 09:57 AM Thread Starter
OK that's what I was hoping but I had read somewhere that having just front LED signals and incandescent backs drew enough power?
Dfroe850 is offline
post #5 of 9 (permalink) Old 02-07-2017, 10:48 AM
yup.EP34
Spockster likes this.
earshaved
BOO
BRING BACK WOLFIE.
"I only carry when I have my pants on"Joe Robinson aka Old Dog
OleDirtyDoc is online now
post #6 of 9 (permalink) Old 02-07-2017, 11:12 AM Thread Starter
Awesome thanks a lot guys. Will be going to Auto zone here shortly and get back to y'all with results!
Dfroe850 is offline
post #7 of 9 (permalink) Old 02-07-2017, 02:37 PM
Nickdwhit's Avatar
https://www.amazon.com/gp/aw/d/B01CC...YVZPUD1T&psc=1
If you don't get what you need at auto zone this should help you.
Sent from my SAMSUNG-SM-G890A using Tapatalk
NIBiker likes this.
1986 vn750
1987 cbr 600 (hurricane)
1996 gsxf 750 (katana)
Nickdwhit is offline
post #8 of 9 (permalink) Old 02-08-2017, 03:25 PM Thread Starter
Got a break in the rain today and made the trip to Auto parts. Had the relay and it worked perfectly. Thanks again Y'all. Now to paint the front light housing to match the black lights!
OleDirtyDoc and NIBiker like this.
Dfroe850 is offline
post #9 of 9 (permalink) Old 02-08-2017, 05:16 PM
That works, but eliminates the power savings of LEDs. For a quite a while, that was the only method available. Still is if you can't get an LED flasher for your system.
2003-19k mi
Me and Cinderella, we put it all together, we can drive it home, with one headlight.
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
