Wiring Harness - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 25 (permalink) Old 03-22-2011, 09:34 PM Thread Starter
Wiring Harness
So I am in the process of replacing the wiring harness in my 86 VN750. I took out the old one and bought a used one from eBay. I went to hook up the "new" one and noticed the connections were different. There was no connector on the "new" harness for the turn signal blinking device...and then 2 connectors near the front of the bike were also different. The eBay listing said it was for 89-06 vulcans...but i was under the impression that it should work for an '86 as well....
khedberg85 is offline
post #2 of 25 (permalink) Old 03-22-2011, 11:06 PM
clock152's Avatar
86 had the turn signal canceling device on it.. 89 will work but you have to do some adjustments... Slim will jump in here in a bit.. he is deploying right now so give him a bit.. he has reworked his whole elct. system.
clock152 is offline
post #3 of 25 (permalink) Old 03-22-2011, 11:31 PM
The `85 to `88 vn750 had the self cancelling signals.
That`s why the ebay listing for the wiring harness was listed as fitting `89 to 2006.
There were not many changes in the 750 over 21 years of production, but there were a few.
Thanks to 750 forum...
Changes in the VN750 over the years
If you have additions or corrections to this document:
- Contact: banton@austin.rr.com
or
- a forum moderator
New Cost:
$5,500 (1985)
$5,500 (1987)
$5,500 (1988)
$_,___ (19__)
$6,090 (1995)
$6,090 (1997)
$6,090 (1999)
$6,190 (2000)
$6,190 (2002)
$_,___ (20__)
Air adjustable forks
- '85-'88 = only years
Brake master cylinder
- '85-'90 = rectangular
- '91-'06 = round
Brake Lever
- '85-'90 = same
- '91-'06 = changed
Clutch lever is the same for all years
Engine color
- '85 only = black
- '86- up = natural aluminum
Engine displacement
- '85 only = 699cc
- '86- up = 749cc
Fuel Cap latching
- '85-'87 = close without key
- '88- up = need key to close ????
Fuel Control Valve
- '85-'__ = RES - ON - PRI (Prime)
- '__-'__ = RES - ON - OFF
Fuel Tank rear vent tubes
- '85-'87 = none
- '88-'98 = tubes
- '99- up = none ????
Grab rails, Sissy bar, Passenger footpeg mounts
- '85-'86 = aluminum
- '87- up = chrome
Instrument bezels
-'85-'__ = aluminum
-'03-'up = chrome
Mirrors
- '__-'__ = rectangular
- '__-'__ = round
Oil filter
- '85-'94 = larger size 2.95" diameter
- '95 up = smaller size 2.76" diameter
Oil filter (mating) plate
- '85-'93 = 13169-1921 = 2.95" (75mm)
- '94 = 13169-1921 = 2.95" (75mm)
- '94 = 13270-1170 = 2.76" (70mm)
- '95 up = 13270-1170 = 2.76" (70mm)
Shock absorber
- '85-'98 = 45014-1304
- '99- up = 45014-1710 older ProTac brackets may interfer with air valve
reported by Jim "Pick" Foster
Side covers
- '85-'86 = Ebony
- '87-'98 = Chrome
- '99-'00 = Gray
- '01 only = Bronze
- '02 only = Black
- '03 only = Red
- '04 only = Ebony
- '05 ____ = _____
- '06 ____ = _____
Wheels
- '85-'86 = painted
- '87-'up = natural
Wiring harness
- '85-'88 have a Turn Signal Control unit
- '89- up Turn Signal Control unit eliminated.
- '85-'88 are NOT interchangeable with 1989 and up
Won't work by leaving the signal circuit open
__________
- '__-'__ =
- '__-'__ =
__________
- '__-'__ =
- '__-'__ =
Paint color listing:
http://f1.grp.yahoofs.com/v1/MKNSQ_P...D08M/color.xls
A # Year Tank colors Side cover
A 1 1985 _______ / _____ Ebony _____-____ & ____
A 2 1986 Black / Red L.V. Red 36002-5183-P5 & 5184-P5
A 2 86 Black / White Ebony 36002-5181-H8 & 5182-H8
A 3 1987 Black / Gray Chrome 36001-1359 & 1360
A 4 1988 Ebony / Gray " " " "
A 5 1989 Ebony " " " "
A 6 1990 Maroon / Black " " " "
A 7 1991 Maroon / Black " " " "
A 8 1992 Blue / Blue " " " "
A 8 92 Green / Green " " " "
A 9 1993 Blue / Gray " " " "
A 9 93 Green / Green " " " "
A10 1994 Green / Blue " " " "
A10 94 Red / Red " " " "
A11 1995 Green / Blue " " " "
A11 95 Red / Red " " " "
A12 1996 Red / Gray " " " "
A12 96 Blue / Silver " " " "
A13 1997 Red / Gray " " " "
A13 97 Ebony / G. Silver " " " "
A14 1998 Bronze / Red " " " "
A15 1999 Ebony / Gray P.C. Gray Blue 36001-1284-VK & 1285-VK
A16 2000 Ebony / Gray P.C. Gray " " "
A17 2001 Graystone / Bronze M.D. Bronze 36001-1284-7R & 1285-7R
A18 2002 Black / Silver P.G. Black 36001-1284-86 & 1285-86
A19 2003 Red / Graystone L.V. Red 36001-1284-2T & 1285-2T
A20 2004 Ebony / Silver Ebony 36001-1284-H8 & 1285-H8
A21 2005 Ebony / Silver Ebony " " "
A22 2006 _______ / _____ _______ -
http://www.vn750.com/forum/11-vn750-general-discussion/9127-top-ten-items-you-would-suggest-new-owner-do-his-new-ride.html
post #4 of 25 (permalink) Old 03-22-2011, 11:39 PM
clock152's Avatar
wow.. ok.. OlHoss.. nailed it!
clock152 is offline
post #5 of 25 (permalink) Old 03-23-2011, 05:13 AM
in short, there are a few different wiring harnesses.. in my case, I was working on my 92 wiring harness and replaced it with another 92, and it was a whole lot different. I found out that there is even a difference between Canada, California< standard US, U.K, and Japanese 750's of the same year... so make sure you order a wiring harness for your exact model of bike...
post #6 of 25 (permalink) Old 03-23-2011, 01:47 PM Thread Starter
Thank you for the responses....I called the seller and he is researching to make sure he has one that will fit an '86 and might let me exchange it for no cost. My next question would be since it only effects the turn signal operation that means the starter should still kick over, but I push the starter button and nothing happens....is it becuase the circuit is not completed somewhere or is my starter shot.....
post #7 of 25 (permalink) Old 03-23-2011, 02:50 PM
Could you start the bike with the old wiring harness?
Is the engine stop switch in the run position?
Then there are 3 safety switches;
-1 operated by the clutch lever
-sidestand
-and a neutral detector
If the sidestand is down, the safety switch won`t let it start with the tranny in gear.
Putting the stand down with the bike in gear and clutch pulled in will kill the engine too.
Sidestand safety switch sometime gets sticky/dirty. Put bike up on centerstand and inspect switch, spray with WD-40 and work contact lever around to clean it out and free it up.
Neutral safety switch won`t let it crank unless the tranny is in neutral,
or the clutch must be pulled in if the tranny is in gear.
Try again with sidestand up (with clean operating switch), clutch in, tranny in neutral and engine stop switch in RUN position.
http://www.vn750.com/forum/showthread.php?t=9127
post #8 of 25 (permalink) Old 03-23-2011, 06:12 PM Thread Starter
-sidestand
No the old harness was totally shot. It is in neautral and on the center stand I hit the button and nothing happens. Took off the starter and used a different cable from the relay switch to starter to see if it was bad and the starter did not move. So i am assuming I need a new starter.
post #9 of 25 (permalink) Old 03-23-2011, 06:26 PM
Did you have a ground cable to the starter body while on the bench?
I only ask because of a similar *oops* incident here a few days ago. lol
Try using booster cables from the car battery to double check the starter.
There are starter rebuild kits on ebay for under $30.
Here is a current link to vn750 starters and related parts on ebay
http://motors.shop.ebay.com/i.html?_...506.m270.l1313
post #10 of 25 (permalink) Old 03-23-2011, 08:50 PM Thread Starter
Thanks...I actually did not have it grounded so I will have to give it a try. If it does not work and I still need to rebuild it is it fairly simple to do?
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
