Distilled water VS Battery acid :doh: - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 19 (permalink) Old 03-10-2009, 11:02 PM Thread Starter
letitflight's Avatar
allright, I am confused here...what is the difference between distilled water and battery acid.
According a mecanic guy, i am supposed to use distilled water to top off the liquid level in the battery. Use battery acid only if the level is really low.
Any idea?
Thanks
PEACE!!!
2005 Vulcan 750
letitflight is offline
post #2 of 19 (permalink) Old 03-10-2009, 11:07 PM
99vulcan750's Avatar
if you spill battery acid on your self it's bad.. if you spill distilled water on yourself, it's not bad :-P
distilled water doesn't have any ionic charge- it's neutralized. it works to increase the level of 'acid' when still between the low and high marks. The only need for adding new battery acid is if you drop way down- say the battery tipped over and leaked.
I may be wrong... but that's what I'm thinking...
'99 VN750 with 8900 miles and growing (3,111 when I bought it 03-22-08)
Ear shave with Unipods
Drilled mufflers and degoat
TOC springs
N/C Street shield EX windshield
Jumbo Saddleman Highway Studded saddlebags
Willie and Max Saddlebag mounting kit
License plate turn signals
Home made sissy bar
Luggage Rack from Scoop
http://youtube.com/user/99vulcan750
99vulcan750 is offline
post #3 of 19 (permalink) Old 03-10-2009, 11:10 PM
after a battery charges, the electrolyte levels change in the acid...adding more acid dilutes the electrolyte levels and makes for a weeker charge... adding distilled water adds electrolytes insted of diluteing them...tap water adds deposites and corrosion to the plates.
post #4 of 19 (permalink) Old 03-10-2009, 11:30 PM Thread Starter
If feel better now...that's what i thought too...
Thanks guys.
The source of my confusion is coming from the french (my native language- some of you might have noticed my grammar), battery acid = distilled water, even thouh everyone knows distilled water isn't acid ....i m getting confused again LMAO
anyway...thanks
PEACE!!!
2005 Vulcan 750
post #5 of 19 (permalink) Old 03-11-2009, 02:01 AM
Love My Baby
rubyrick's Avatar
Not to add to your confusion, but...
Distilled water does not have any electrolytes, it's simply H2O, hydrogen and oxygen, nothing more. That's good because, as slimvulcanrider stated, there's nothing to deposit on the battery plates like tap water has.
Battery acid is sulfuric acid. You would normally only add this prior to initially charging the battery when you first bought it. After that, just add distilled water when the levels are low. The only other time to add sulfuric acid is if a particular cell has a very low specific gravity even after being filled with distilled water above the low line and then fully charged, and that means you would need to check the specific gravity of the fluid in all the cells. Most of the time, however, the reason a battery fails is not because of low acid levels, but because the battery has become sulfated or has filled with sediment and therefore has shorted out. Adding sulfuric acid won't help a shorted out battery.
By the way, every time you connect a charger to a non-maintenance free battery, the kind with the vent tube, the battery looses some fluid through the vent tube. So frequently charging your non-maintenance free battery, even with a battery tender, will make it even more important to check your battery fluid levels at least monthly. Otherwise you will find yourself stranded with a dead battery that you just charged.
It's much easier to simply replace the stock battery once it fails with a maintenance free glass mat battery. You won't have to worry about checking the specific gravity and this battery will hold a charge longer. There's practically no chance that this battery will spill acid all over the delicate electrical components near the battery case, and you will be less likely to be stranded somewhere because you didn't check your battery fluid levels every month.
Rubyrick
MY BABY...
'05 VN750
16,000 miles +
Kawi tank bib
Kawi rear rack
Small windshield
DEKA M/F battery
LED license plate frame
X
rubyrick is offline
post #6 of 19 (permalink) Old 03-11-2009, 03:54 AM
Simple Solutions
seebeeare's Avatar
Nice write up Ruby wouldnt/couldnt have said it like that
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
How To Test the Stator
seebeeare is offline
post #7 of 19 (permalink) Old 03-11-2009, 11:26 AM
X2 do not add acid
post #8 of 19 (permalink) Old 03-11-2009, 03:21 PM Thread Starter
Great tips guys, merci beaucoup!!!!Thanks!!!
PEACE!!!
2005 Vulcan 750
post #9 of 19 (permalink) Old 03-11-2009, 03:32 PM
93VN750's Avatar
Another advantage of the MF or AGM style battery is it has a lower series resistance than a standard wet cell so it needs less current from our precious charging system to get recharged. This lower series resistance also helps keep the battery cooler as it does not "create" as much heat when charging. Since the R/R is bolted to the battery box........
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #10 of 19 (permalink) Old 03-11-2009, 05:20 PM
Jon
I did not know this, Jon. thanks for the info.
X2 to 99, rubyrick, and niterider above. You should only ever need to add DISTILLED water to your battery. Needing to add more sulfuric acid would be an exceptional case, as outlined by rubyrick.
You will also avoid corrrosion and sediment or calcium buildup in the radiator of your bike, (or car), if you only use distilled water in it as well. FWIW
http://www.vn750.com/forum/11-vn750-general-discussion/9127-top-ten-items-you-would-suggest-new-owner-do-his-new-ride.html
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
