Oil/Coolant leak - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 10-31-2009, 06:03 PM Thread Starter
Oil/Coolant leak
Hey Yall,
I'm a new rider (started this year) though I've done a bike rebuild (a 93 GSXR 750 with a seized engine, now sold) and I've put in a lot of work on my 83 maxim 750 which is my current ride.
I'm hoping to upgrade my ride to something a little more comfortable so I've bought myself a 86 Vulcan 750 (~36,000km) as a fixer-upper project for this winter.
It is a project bike as the head is leaking oil from around the forward cylinder head gasket area and anti-freeze is getting into the oil. I expect that I'll have to replace the head gasket though I guess with these things it could be a cracked head or a faulty o-ring somewhere.
Right now I am looking for a complete gasket set as I would like to be able to replace as many gaskets and o-rings as possible while I'm in there. However I am having a very hard time finding a set so if anyone has any tips for where to look that would be great.
Also I would greatly appreciate hearing about other things I should check out while I'm in there as I don't really feel like doing the job twice.
Cheers
Andre Bezanson
fore4runner is offline
post #2 of 12 (permalink) Old 10-31-2009, 06:33 PM
Simple Solutions
seebeeare's Avatar
unfortunatly there is not a complete gasket oring kit ... I'll peak through my paperwork and see if i can find a parts list for you... your best bet is cheap cycle parts.com however where are u located u said km so im guessin not in the states... lol n e who i'll see what i can find , but a mungest the list of stuff u need is a mechanical seal, and id also re ring and change the dampeners while your in ln there ...
that mechanical seal and the gasket on the clutch side cover are the number one culpret for water in the oil ...
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
How To Test the Stator
seebeeare is offline
post #3 of 12 (permalink) Old 10-31-2009, 06:35 PM
Simple Solutions
seebeeare's Avatar
11004-1135 - GASKET-HEAD Kawasaki 2 $20.12 $40.24
11060-1361 - GASKET,CYLINDER BASE Kawasaki 2 $4.95 $9.90
13008-1077 - RING-SET-PISTON,STD Kawasaki 2 $26.29 $52.58
11060-1088 - GASKET,CLUTCH OUTSIDE Kawasaki 1 $5.55 $5.55
11060-1089 - GASKET,GENERATOR COVE Kawasaki 1 $10.64 $10.64
11060-1090 - GASKET,CLUTCH COVER Kawasaki 1 $12.36 $12.36
11060-1091 - GASKET,TRANSMISSION C Kawasaki 1 $3.81 $3.81
670b2014 - Kawasaki 4 $0.51 $2.04
670d1509 - O RING Kawasaki 1 $1.63 $1.63
11060-1086 - GASKET,GEAR CASE Kawasaki 1 $7.12 $7.12
11060-1092 - GASKET,OIL FILTER Kawasaki 1 $3.27 $3.27
92055-1021 - Kawasaki 1 $2.31 $2.31
670d2020 - O RING Kawasaki 1 $2.19 $2.19
49063-1057 - SEAL-MECHANICAL Kawasaki 1 $17.97 $17.97
92075-1747 - DAMPER Kawasaki 4 $5.11 $20.44
92075-1748 - DAMPER Kawasaki 2 $6.12 $12.24
11060-1083 - GASKET,SEPARATER COVE Kawasaki 2 $2.31 $4.62
14043-1056 - FILTER,OIL Kawasaki 2 $3.77 $7.54
92055-049 - Kawasaki 2 $1.48 $2.96
92055-1272 - RING-O,27.7MM Kawasaki 2 $1.92 $3.84
11060-1119 - GASKET,EXHAUST PIPE Kawasaki 2 $3.71 $7.42
92051-005 - OIL SEAL,TB13225.5 Kawasaki 1 $3.07 $3.07
also need a clutch hub holder and a roter puller 18x1.5mm bolt yammabond case sealer if u split the cases
this list includes new rings , gaskets and orings the only missing orings are the acct's
al from cheapcyclearts.com
goodluck u can run this list by lance... but this is from the ordersheets from my rebuild i already took off the shifter parts from the ist
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
post #4 of 12 (permalink) Old 10-31-2009, 09:27 PM Thread Starter
Amazing
Thanks for the list Seebeeare! That will be a huge help. I guess while I'm in there I should probably lap the valves and upgrade the ACCT springs though I definitly have some research to do before I get started as I have a lot to learn about these bikes. The whole damper system and hydraulically adjusting valves are completly new to me so I'm definitly not going to rush into this one.
I'm located in Nova Scotia and it looks like my best bet is to go with cheap cycle parts as those are the best prices I've seen yet.
I'll probably try to take the time this coming weekend to run a compression test on the engine and possibly rip her down to see if she's running std ring. After that I hope to order up the parts and get er done.
Once again thanks,
Andre
post #5 of 12 (permalink) Old 10-31-2009, 11:14 PM
flitecontrol's Avatar
You also need to replace the tie rod assembly in the shifter mechanism with part 39110. The original rod in your bike is weak (design flaw) and will fail. The newer one was made for later models and is much stronger. Info courtesy of lance.
"Black Beauty"
Currently 23,298 miles
Old Blue
flitecontrol is offline
post #6 of 12 (permalink) Old 11-01-2009, 12:34 AM
Hoser
junkyardroad's Avatar
Maybe not. They are not that different if you know the basics. The posts above are right. These guys are very helpful as you have seen. You can get viton valve seals from ebay.
Cheapcycleparts is good. They are a little slower to ship though.
I have to say the VN750 is the most comfortable M/C I have ever ridden.
1986 VN750A(2) 12224 miles.
junkyardroad is offline
post #7 of 12 (permalink) Old 11-01-2009, 12:37 AM
The Professor
lance328's Avatar
Here is the list I have on hand, it has everything for an overhaul AND not A COMPLETE REBUILD!!
QTY SKU DESCRIPTION
1 11060-1088 GASKET, CLUTCH OUTSIDE COVER
1 11060-1089 GASKET, GENERATOR COVER
1 11060-1090 GASKET, CLUTCH INNER COVER
1 11060-1091 GASKET, TRANSMISSION COVER
1 11060-1086 GASKET, BEVEL GEAR
2 11060-1082 GASKET, EXHAUST MANIFOLD
2 11060-1119 GASKET, EXHAUST DOWN PIPE
2 11060-1361 GASKET, CYLINDER BASE
2 11060-1083 GASKET, SEPERATOR COVER (CAM CAP RESERVIOR)
2 11004-1135 GASKET, CYLINDER HEAD
1 92055-1319 O-RING, GENERATOR OUTSIDE COVER
3 92055-049 O-RING, OIL FILL CAP AND SPARK PLUG TUBES
3 92055-109 O-RING, OUTSIDE GENERATOR COVER SCREWS
1 670D1509 O-RING, IMPELLER SHAFT (WATER PUMP)
1 49063-1057 MECHANICAL SEAL (WATER PUMP)
1 92055-112 O-RING, THERMOSTAT HOUSING
1 671B2525 O-RING, WATER PIPE TO THERMOSTAT HOUSING
4 92055-1308 O-RING, COOLANT PIPE (FROM CLUTCH COVER TO ENGINE CASE) "TWO ON EACH END"
2 670B2014 O-RING, CYLINDER HEAD COOLANT PIPE
2 92055-1272 O-RING, SPARK PLUG TUBE
1 92055-1358 O-RING, SIDE OIL DRAIN PLUG (17MM)
2 670D2021 O-RING, ACCT (AUTOMATIC CAM CHAIN TENSIONER)
2 670B2018 O-RING, TENSIONER PLUG ABOVE THE "ACCT"
8 92049-1062 OIL SEAL, VALVE STEM (I PREFER THE "VITON" SEALS ON EBAY)
2 14043-1056 OIL FILTER (IN HEAD BETWEEN CAM CAP AND HEAD)
1 16097-1058 OIL FILTER ASSY. (FILTER SCREEN BEHIND SIDE OIL PLUG)
1 92055-1276 O-RING, STARTER MOTOR TO ENGINE
1 92051-005 OIL SEAL, SHIFT SHAFT (GENERATOR COVER)
4 11009-1344 OIL PIPE GASKET (EXTERNAL OIL PIPE TO HEADS)
2 11009-1105 OIL PIPE GASKET (OIL PRESSURE SENDING UNIT)
4 92075-1747 BALANCER DAMPER !!!!!!!!! MUST REPLACE !!!!!!!!
2 92075-1748 BALANCER DAMPER !!!!!!!!! MUST REPLACE !!!!!!!!
PARTS YOU MAY OR MAY NOT NEED
2 13008-1077 PISTON RING SET, STANDARD
1 59256-1058 IMPELLER (WATER PUMP)
!!!!!!!!!!!!!!!!!!! THE LIST ABOVE IS EVERYTHING TO "REFRESH" THE ENGINE!!!!!!!!!!
IT DOES NOT INCLUDE ANY BEARINGS OR ANY PARTS YOU MAY NEED IF YOU HAVE TO SPLIT THE CASES OR ANY PARTS DUE TO AN MECHANICAL FAILURE.
VITON VALVE STEM SEALS
http://cgi.ebay.com/ebaymotors/KAWAS...item45eee53c4a
CONTACT THIS PERSON FOR THE SEALS, HIS AUCTIONS JUST ENDED FOR THE VN750. HE HAS PLENTY IN STOCK AND WILL RELIST SOON.
If you do not need to split the case halves you will NOT need any special tools.
If you re-ring you WILL have to de-glaze the cylinder walls. If you don't the ring will NOT seat properly.
DO NOT use any RTV Silicone sealant, use Permatex High Tack Spray Gasket sealant on the paper gaskets and Permatex Ultra Copper Spray Gasket sealant on the head gasket.
NO WARRANTY EXPRESSED OR IMPLIED!!!!!!!!!!! LOL
85 VN700 "Old Yella"
REBUILT ENGINE
CUSTOM PAINT
VANCE & HINES CRUZERS
VOLTMETER
SYNTHETIC BRAKE FLUID
SYNTHETIC OIL & GEAR LUBE
PLEXISTAR 2 WINDSHIELD
SPLINES LUBED
ACCT'S GREASED W/TOC SPRINGS
COASTERD
LEATHER SADDLE BAGS
LEATHER TOOL AND ROLL BAG
PICKUP COILS GAPPED AT .018"
NGK CAP, WIRES, IRIDUMS
CUSTOM GRIPS, MIRRORS, LEVERS
ORIGINAL STATOR & R/R 14.5v
DEKA MF AGM ETX15L
lance328 is offline
post #8 of 12 (permalink) Old 11-01-2009, 12:50 AM
GIMPYRDR's Avatar
I would add checking the R/R and stator just to be safe. Also you may want to clean and check the splines on the drive shaft. Anything else, I encourage you to check the Vulcan Verses.
2005 Vulcan 750
Black and Silver
Saddlebags
OEM Hghwy Bars
O-ring Footpegs
OEM Luggage Rack
V&H Exhaust System
TOC ACCT Rebuild
Die Hard Gold AGM MFB
Spline Lube every tire change
VN750 #4393
VROC #31065
TexasVROC
GIMPYRDR is offline
post #9 of 12 (permalink) Old 11-01-2009, 01:23 AM
Simple Solutions
seebeeare's Avatar
dont you need the clutch holder tool and the rotor puller?
and the shift tie rod would need the case split...!
Stator #3
MF AGM
DeGoated
Ears Shaved
Rebuilt
post #10 of 12 (permalink) Old 11-01-2009, 01:57 AM
The Professor
lance328's Avatar
I just noticed he has an 86', YES he will need those tools to split the case and replace the shifter tie rod. He not gonna be happy.
REBUILT ENGINE
CUSTOM PAINT
VOLTMETER
SPLINES LUBED
COASTERD
LEATHER SADDLE BAGS
DEKA MF AGM ETX15L
lance328 is offline
Tags
oil leak coolant
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
